Old 7-Apr-2013, 10:00 PM   #2
All of your receivable Digital Broadcast Tv stations/channels are one direction ~~South.
The Canada Digital Broadcast Tv stations/channels will be received.
And WCFE , PBS , will be received.
_________________________________________________________
And Yes it is true that the following USA Digital Tv stations/channels are weak and -Yes- receivable signal strengths , and have 2 edge path obstructions and are far away at 90.2 miles.
You have nothing to lose and Tv stations to gain by trying for the following USA Digital Tv stations/channels.
The only way to find out if some or all of the following USA Digital Tv station/channels are reliably received is put a antenna -Up High - in the air.
WCAX , CBS.
WPTZ , NBC.
WETK , PBS.
WVNY , ABC.
WFFF , FOX.
Above the roof ^UP^HIGH^ in such a manner that the roof and house are not blocking reception to the ~South.
Install a Winegard HD7698P antenna aimed at about 167 degree magnetic compass direction.
The Antennas Direct CPA-19 preamp has been discontinued , if you can find one , use the CPA-19 preamp.
If not then use a.
Install a Winegard HDP-269 preamp.
Here are some places to buy Antennas and HFS splitters and etc. .
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.amazon.ca.
http://www.winrgarddirect.com.
http://www.hollandelectronics.com.
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path reflecting , blocking , OTA=Over The Air , Digital Broadcast Tv Reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7698P antenna , ^UP^High^ , at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
