Old 7-Apr-2013, 7:33 AM   #8
A simple reception situation using 1 antenna.
For reception of the , Pending Applications Included Digital Tv stations/channels in the Green and Yellow reception zones of the tvfool radar report and channel list.
The signal strengths in the Green and Yellow reception zones are Strong Signal Strength at your location and are , LOS=Line Of Sight , LOS is the best reception.
Above The Peak Of The Roof in such a manner that reception is not blocked by the roof and house in the directions of , west , south west , north east.
Install a Antennas Direct Clear Stream 2 Complete UHF/VHF antenna.
http://www.antennasdirect.com/store/...VHF-Combo.html.
Remove the Reflector Screen from the CS2 Complete antenna.
The reflector screen is not the UHF reception loops.
The reflector screen is not the VHF reception rods.
The reflector screen is the screen , remove the reflector screen and the CS2 Complete antenna will receive 2 directions , the front of the antenna and back of the antenna.
Aim the front or back of the CS2 Complete antenna at about 50 degree magnetic compass direction.
And the CS2 Complete antenna will receive the Digital Tv stations/channels to the , west , south west , north east.
The CS2 Complete comes with a , J pole type antenna mount.
______________________________________
Try reception without a antenna system amplifier.
For 3 Tv's connected use a simple common 3 way splitter.
For 4 Tv's connected use a simple common 4 way splitter.
_______________________________________
If a antenna system amplifier is required with 3 or 4 Tv's connected , then use a , Winegard 'Boost' LNA-100 amplifier.
The Winegard 'Boost' LNA-100 amplifier is not water resistant so the amplifier is to be installed inside.
The Winegard 'Boost' amplifier is installed between the CS2 Complete antenna and before the splitter.
The closer the amplifier is to the antenna , the better.
http://www.solidsignal.com.
http://www.amazon.com.
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path reflecting , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the CS2 Complete antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
