Old 7-Apr-2013, 6:11 AM   #6
Reliable reception of WILM on real channel 40 looks easy based on your TV Fool Report.
You have several good options open to you... I would suggest an Antennas Direct DB2e facing about 260° per a compass.
If you want to add WCTI, real channel 12 to the lineup you can add a Winegard YA1713 pointed at 38° compass. You would be able to use a UHF/VHF combiner to join the two signal sources into a common down-lead.
http://www.antennasdirect.com/store/...r-Antenna.html
http://www.antennasdirect.com/store/..._combiner.html
http://www.winegarddirect.com/viewit...13%29&p=YA1713
Unless you have more than two TVs to feed I would defiantly try this with no amplifier.
