It would be interesting to see a second TV Fool report based on your roof peak height. Much of the Federal Way area sits on a somewhat level (a relative term in the Seattle area) plateau. Your first report is based on the default height of 10' and may be making the situation seem worse than it really is.
What if it's possible to use a small antenna mounted on a 'J-pole'... very often these installs are so low profile that only you know they're present.
Reason: Sp.
