Looks like a nice list of networks and IND's in your report.
I would avoid an omni or multi directional antenna and use a fixed aim directional combination. I would aim the UHF at 73° true, the VHF at 198° true. Mount as high as possible.
I would choose a large UHF and separate VHF like the 91XG and YA 1713
http://www.solidsignal.com/pview.asp...u=853748001910
http://www.solidsignal.com/pview.asp...u=615798304867
I would combine the two using a Channel Master CM7777
http://www.solidsignal.com/pview.asp...ku=02057207774
I think that combination would give you the best chance at reliable reception of the stations in the top half of your report. I would try using a passive 4W splitter, two amplifiers in the same run often causes problems.
Reason: Aim point correction
