Old 6-Apr-2013, 2:31 AM   #7
A simple reception situation.
The current Tv stations/channels being transmitted and received , Canada , USA , Mexico , are.
UHF channels 14 thru 51.
Your location has receivable Tv stations/channels.
UHF band channels 14 thru 51.
Install a Winegard YA1713 VHF high band channels 7 thru 13 antenna aimed at about 42 degree magnetic compass direction.
And install a Antennas Direct DB4e , UHF channels 14 thru 51 antenna aimed at about 15 degree magnetic compass direction.
Connect the 2 antennas together with a Antennas Direct UHF/VHF combiner/diplexer.
Antennas Direct EU385CF-1s .
Connect the YA1713 to the VHF connection of the combiner.
Connect the DB4e to the UHF connection of the combiner.
The remaining connection of the combiner is connected to a Antennas Direct PA-18 preamp.
____________________
Buy the HFS splitters at one of the sellers listed below or buy from , http://www.hollandelectronics.com.
______________________________
Here are some places to buy antennas and etc. , in Canada.
http://www.saveandreplay.com.
http://www.trentondistributors.com.
Here are some other places to buy antennas and etc. .
http://www.solidsignal.com.
http://www.amazon.com.
http://www.antennasdirect.com.
_________________
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path reflecting , blocking , Digital broadcast Tv stations/channels and so do buildings and other obstructions including your own roof and house.
It is best to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select . 'Air Channels' / 'Antenna Channels'.
______________________________________________________
Here is a way to receive All of the USA PBS channels and more Tv channels for free.
A good places to start for, KU Band , FTA -->Small Dish<-- is.
http://www.ftalist.com.
Saveandreplay sells FTA.
FTA is receivable , Canada , USA , Mexico .
FTA KU-Band -->Small Dish.
And Also.
The -->Big Dish<-- , C-Band FTA , is getting more and more free Tv channels.
www.global-cm.net , lists channels for Both , KU-Band and C-Band.
http://www.global-cm.net/mpeg2central.html.
http://www.global-cm.net.
Last edited by teleview; 4-Jun-2013 at 3:18 AM. Reason: Clarify information and typos.
