The UHF signals are weak but still worth trying for. I'd use an Antennas Direct DB4e... high gain and wide forward beam width.
An Antennacraft Y10713 or Winegard YA1713 would be the right tool for the signal on real CH-12.
Antennas Direct PA-18 preamp or an Antennacraft 10G222 would be options to consider for preamplifiers. If you go with the PA-18 you would need a UHF/VHF combiner.
