Old 5-Apr-2013, 8:30 PM   #4
I would expect you'd have more reception reliability problems when using a small antenna such as the ANT-751.
You situation certainly improves at 25' AGL. I'm still in favor of a large antenna such as the HD7696P.
I would encourage you to politely assert your right to receive OTA TV... however, if you choose to use a smaller antenna, the UHF performance of Antennas Direct DB4e is on par with the Winegard product so far as gain is concerned. The DB4e lacks intentional support for real channel 13 and lower, so you would likely have trouble with KCTS & KSTW. KCPQ is operating on two frequencies so you'd be able to receive real CH-22.
