Old 5-Apr-2013, 8:15 PM   #2
Though your TV Fool Report is flagged with the cautionary statement, "WARNING: Address was only resolved to zip code level and might not be that close to your actual location. For more accurate results, try entering a specific address or coordinates.", I presume the terrain is relatively flat...
If not for the specific goal of KCWX reception, a single antenna solution would be in order.
KCWX presents a couple of challenges. First, the stronger signal from KLRN on real CH-9 is going to offer some adjacent channel interference. Then the much weaker and distant KIII may on occasion produce some co-channel interference... this would be dependent on atmospheric conditions (weather). Still, I would certainly try for it, using a Winegard YA1713 pointed at 159°.
For the rest of the strong local stations, use a small 2 or 4-bay UHF antenna such as the Antennas Direct CS2, CS4 or DB4e --- Channel master CM-4220, CM-4221... Antennacraft & Winegard also have some similar options.
Combine the two antennas using a UHF/VHF combiner such as the Antennas Direct EU385CF.
