Old 5-Apr-2013, 7:48 PM   #3
alavochin
I'm also in the Greater Seattle area. Yes, the major networks are all broadcast in HD (720p or 1080i depending on the particular network). There area also may 'minor' networks being broadcast, usually in SD, 480i. Check out http://www.rabbitears.info/market.php for details.
It would be very helpful to see a TV Fool report based on an antenna height of 25' AGL.
Your first post is showing conditions at the default height of 10'. If this is the best available, I would opt for an outdoor mounted Winegard HD7696P or HD7698P pointed north.
Here is a report from 25' http://www.tvfool.com/?option=com_wr...1dda03bafa7b60
I was looking for point something outside but a little less discreet. We will in a community and even though they aren't able to say anything about the antenna according to FCC, I still would rather not piss them off. What do you think of the ANT751R for my situation?
alavochin is offline   Reply With Quote
