Old 5-Apr-2013, 7:24 PM   #2
I believe I have successfully repaired your TV Fool report link but please double check to be sure the link points to your report.
If the TVFR is correct, WGGB and WTNH are your ABC affiliate options. In either case a single antenna indoors or in the attic is going to have a difficult time providing reliable reception of signals to the SE if its turned toward either ABC option.
I would opt for an Antennacraft Y10713 or Winegard YA1713 pointed at WTNH (196° compass) and an Antennas Direct DB4e facing about 145° compass. Combine the two antennas with an UHF/VHF combiner such as the Antennas Direct EU385CF.
Reception of the UHF signals from the SE would likely do quite well with the DB4e in the attic, but I would opt for roof mounting given the signal conditions faced by the High-VHF antenna aimed at WTNH.
