Old 4-Apr-2013, 8:11 AM   #3
The Cabin reception location.
The Tv reception signal strengths are Very Weak.
Looks like 2 Digital Tv stations channels will be received.
WBRE-DT Real VHF Digital channel 11 , virtual number (28.1) NBC.
WYOU-DT Real VHF Digital Channel 13 , virtual number (22.1) CBS.
Install a Winegard YA1713 , channels 7 thru 13 , antenna aimed at about 121 degree magnetic compass direction.
_______________________________________
As often happens with Tv reception in hill and mountain areas , the Tv signals 'Bend' a little downward as the the Tv signals travel across the hills and mountains.
The Tv signal strength - improves - a little , lower to the ground.
Even as low as 1 foot above the ground.
The effect is not evenly distributed and varies with height and location.
Try lowering and raising the YA1713 antenna up and down and change location.
Probing for best reception.
The Tv reception is Very Weak signal strength.
_____________
All electric and electronic circuits such as antenna amplifiers and all other electric and electronic circuits generate noise.
Noise adds a masking effect over the desired signal.
Install a ULTRA Low Noise Booster Amplifier.
A Kitztech , KT-200-COAX TV Antenna Booster Remote Power-Coax Fed. Amplifier.
The remote power coax fed amplifier provides the flexibility to install the booster unit , outside or inside.
http://www.kitztech.com.
_______________________________________________________________
WQMY REAL UHF Digital Channel 29 , virtual number (53.1-2-3) MyNetwork and digital sub channels , FOX and CW.
Might be received.
As a Test of reception , disconnect the YA1713 from the Kitztech amplifier and connect a Channel Master CM4228HD UHF antenna aimed at about 262 degree magnetic compass direction.
The same antenna height and location situation applies.
If reliable reception happens for WQMY , then connect the CM4228HD antenna and the YA1713 antennas together with a UHF/VHF combiner.
A Antennas Direct , EU385CF-1s , combiner.
Connect the CM4228HD antenna to the UHF connection of the combiner.
Connect the YA1713 antenna to the VHF connection of the combiner.
And the remaining connection of the combiner connects to the Kitztech amplifier.
For outdoor coax and connections that are exposed to weather/water.
Use the coax that has the , Compression type connectors , not the Old crimp type connectors on the ends of the coax.
And to make double sure that water does not get into coax and connections , wrap with Coaxseal , http://www.coaxseal.com.
Here are places to buy antennas and etc. .
http://www.solidsignal.com.
http://www.amazon.com.
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path reflecting , blocking , Digital Broadcast Tv Reception and so buildings and other obstructions including your own roof and house.
It is best to install the Antenna/s at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
_____
The Tv's Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the TV Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
Here is a way to receive All of the PBS channels/services and other channels/services - for free.
FTA = Free to Air , -->Small Dish<-- Satellite Tv Reception.
The channels are 100% Free to receive.
No descrambler.
And Yes it is 100% Legal.
Here is a good place to start , http://www.ftalist.com.
