Tv Reception
You know as well as I do Tigerbangs that there is more to it. With an exact address to go to it is possible to have a look around and see exactly what the situation is. You know as well as I do that it is some times possible to receive reflected signals off of close by mountain sides. You know as well as I do that it is some times possible to adj. the antenna different ways from normal so as to receive the television transmissions. You are with holding information because you know that the question asker does not know any better. Mazy I will help you if possible to find a way to receive broadcast digital television.
