Old 3-Apr-2013, 11:34 PM   #3
Your reception location has receivable Digital Broadcast Tv stations/channels in All 3 Tv bands.
VHF Low band channels 2 thru 6.
UHF band channels , 14 thru 51.
I recommend a All channel antenna.
Install a Winegard HD7000R , All channel antenna aimed at about 346 degree magnetic compass direction.
Attic and indoor Tv reception Is Not a reception friendly location and Never Will Be a reception friendly location.
Signal attenuation , electric/electronic interference , multi-path/reflections-signals bouncing all around.
That said , the Tv transmissions reception is Very Strong Signal Strength at your location.
A antenna system amplifier is not required.
And Yes you can start with the HD7000R antenna installed in the attic.
For 4 Tv's connected use a simple common 4 way splitter.
_________________________________________________
As time goes by and you notice some reception issues that are not resolvable by adjusting the aim or location of the HD7000R antenna in the attic.
Then move the HD7000R antenna to above the Peak Of The Roof in such a manner that reception is not blocked by the roof or house in the directions of , north - north west , north east , east , south east.
The Winegard DS3000 , J type antenna mount , makes a good mount for the HD7000R antenna , inside or outside of the attic.
http://www.solidsignal.com.
http://www.amazon.com.
