Old 3-Apr-2013, 10:29 PM   #29
The ANT-751 is rather small when chasing after the Albany signals. But you have it, so if you're comfortable working on your roof, it's a very simple experiment to turn the antenna to point the other way.
If you can keep the test simple by connecting only the antenna and a single TV, you'll eliminate questions re. the integrity of components that could be causing some of the other problems you've been troubleshooting. Again, be sure to rescan the TV when you make a change to the system (new antenna, aim-point, add or remove a component, etc.).
