Hi Teleview, As an example, if I point my antenna to say 130 degrees, it will be aiming through some trees. If I instead point the antenna at around 80 degrees it will be pointing to an area that is void of trees. I was wondering if the 80 degree heading would catch the signals from the towers better since it would have less obstruction.
Thanks!!
