More questions to the group
When siting an antenna, do you think it would be better to mount where there is a better path to clear sky, rather than through the trees, even though it is not in the most optimal bearing for where the antenna's are located?
It is strange that the best channel I receive is channel 13 with the CS-4. Why would that be given it is a UHF antenna?
Is it acceptable in this business to buy and assemble an antenna like the Winegard HD7698P, and, if it is not what you had hoped, return it after disassembling it?
Thanks!!
