Old 3-Apr-2013, 1:20 AM   #6
Digital Tv reception on the Valley Floor at your location with a Simple ANT751 antenna mounted above the Peak Of The Roof so the roof and house are not blocking reception to the , north east and west , will receive these Local Strong Signal Strength Digital Tv stations/channels.
WMUR-TV REAL Digital VHF Channel 09 , virtual number (9.1-2) ABC and MeTv.
WNEU-DT REAL Digital UHF Channel 34 , virtual number (60.1) Telemundo.
WPXG-DT REAL UHF Digital Channel 33 , virtual number (21.1-2-3) ION and Qubo and ION Life.
WENH-TV REAL VHF Digital Channel 11 , virtual number (11.1-2-3-4) PBS and PBS Explore and PBS World , PBS Kids.
_______________________
Aim the ANT751 antenna at about 65 degree magnetic compass direction.
The ANT751 comes with a , J type antenna mount.
________________________
The signal strengths of the above listed Digital Broadcast Tv stations/channels are Strong Signal Strength , No amplifier is required.
The ANT751 antenna and coax Must Not Be Connected to the pay cable system coax or coaxes in any way shape or form. Zero , Zilch.
Yes the coax or coaxes that are , in/on the house can be used to get the Antenna Reception to a Tv or Tv's , those coax or coaxes Must Be Disconnected from the pay cable system.
Do Not mix pay cable and antenna reception on the same coax.
___________________________________________
----> A antenna system amplifier is not required<----. The local Tv reception is strong signal strength.
For 3 Tv's connected use a simple common 3 way splitter.
_____________________________________________________________
To receive the Distant and Very Weak signal strength.
WCSH-DT REAL UHF Digital Channel 44 , virtual number (6.1) NBC.
WBZ-TV REAL UHF Digital Channel 30 , virtual number (x) CBS.
And some other network channels.
A Winegard HD7084P antenna and a Antennas Direct CPA-19 preamp will be No Less then 150 feet above ground.
The cost of getting a antenna that high with a new tower and etc. , will Zoom Past $2,000.00.
The valley floor is not a good place for distant weak signal strength reception.
If the reception location is On the Surrounding Hills , reception is Easy , a roof top antenna would receive , many , many , many , many , Digital Tv channels.
