Yes drop amps and distribution amps are more resistant to overload then a preamp.
That is true.
And is a interesting point.
However.
The ANT751 antenna is to small for the job of receiving the Very Weak Tv transmissions at the bottom of the 'receivable' tv stations list.
The way to Avoid Any Type or Kind of Amplifier Overload is Not Use a amplifier of any type or kind.
To do that , use a Bigger antenna , As In , Bigger Antenna.
Not somewhat bigger , but , --> Bigger as in Bigger.
A Bigger Antenna Will Receive More Signal , receiving more signal , means Stronger Signal Strength in the antenna system.
Stronger Signal Strength delivered from the antenna , Can mean no amplifier required.
If No Amplifier is used then the amplifier will not be overloaded because there is no amplifier.
