Old 31-Mar-2013, 12:30 AM   #3
Super Simple Reception Situation.
That will receive , Many , many , many , many , many , many , many , Digital Tv stations/channels.
Above the roof install a Winegard HD7000R antenna aimed at about 75 degree magnetic compass direction.
Use a Winegard DS3000 , J type antenna mount.
Instal the HD7000R antenna Above the Peak of the Roof in such a manner that the reception is not blocked by the roof and house in the directions of , east / north east , north , west.
The Digital Tv signals are Strong and Easy to Receive.
No antenna system amplifier is required.
For 3 Tv's connected use a simple common 3 way splitter.
For 4 Tv's connected use a simple common 4 way splitter.
________________________
Here are places to buy antennas and etc..
http://www.solidsignal.com.
http://www.amazon.com.
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path / reflecting , blocking , OTA=Over The Air , Digital Broadcast Tv Reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
As always , attics and the inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Attenuation , electric/electronic interference , multi-path reflections - signals bouncing all around , blocking , Tv reception.
__________
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
