Old 23-Oct-2010, 12:14 AM   #14
Originally Posted by Chasseur View Post
Thank you all.
I guess I will get a directional antenna for the roof. If I get satisfied with this setup, maybe i'll upgrade with a rotator later to grab other channels.
One more question regarding the coax wiring: is it possible that some interferences are being grabbed by the RG6 cable and not the antenna?
Coax can fail, but the most common problem I can think of would be a bad connection between the coax shield and connector body. That will allow signal to 'leak' into and out of the coax.
