Old 30-Mar-2013, 6:20 AM   #16
Ynot713
Originally Posted by teleview View Post
Connect a NEW as in --> NEW loooong coax to the matching transformer that is connected to the antenna.
Run the NEW loooong coax -->directly<-- through a open door or window and connect 1 Tv.
NO amplifier , NO power injector , NO power supply , NO couplers , NO splitters , NO nothing.
It is the , Antenna , the matching transformer , the coax , the Tv.
Scan for Digital Broadcast Tv channels , Not cable channels.
Reception Now??
If not then install a NEW matching transformer.
And Yes I know you installed a new matching transformer , install a NEW one anyway.
Reception Now??
I did that already with a NEW cable. I did a broadcast scan. I do get reception, but about 6 channels less than I do with the indoor monoprice amp connected directly to the TV.
I am going to buy another matching transformer to see if it works any better.
Thanks Again for your continued help.
Ynot713 is offline   Reply With Quote
