Old 29-Mar-2013, 11:39 PM   #4
The signal strengths at 25 feet above the ground , are Weak to Very Weak at your reception location and have 2 edge path obstructions = hills and mountains.
I recommend a big antenna that receives more signal.
Install a Winegard HD7698P antenna aimed at about 95 degree magnetic compass direction.
Install the HD7698P antenna Above The Peak Of The Roof in such a manner that the reception is not blocked by the roof and house in the directions of , east / south east.
_______________________________________
Weather-water damage is common.
Recommend replace the coax that goes from the antenna to the connection at/on/in the house with New coax that has the Compression type connectors on the ends of the coax , not the Old crimp type connectors.
-->ALL<-- other Outside coax and coax connectors and connections are suspect of being bad , Inspect All Connections With A Honest Eye.
To make double sure that weather water damage will not happen , wrap all coax/connectors and the coax on both sides of the connectors and etc. , with Coaxseal , http://www.coaxseal.com.
Install a Antennas Direct CPA-19 preamp.
_________
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
Here are some Strong and Sturdy antenna mounts.
http://www.ronard.com/909911.html , install a 5 or 7 foot tripod antenna mount.
http://www.ronard.com/34424560.html , install the #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
Here are some places to buy antennas and etc.
http://www.solidsignal.com.
http://www.amazon.com.
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path reflecting , blocking , OTA=Over The Air , Digital Broadcast Tv Reception , and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7698P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channels scan for cable tv channels.
DO NOT channels scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels / 'Antenna Channels'.
Digital Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do a double channel scan.
http://www.dtv.gov/rescan.html
