Old 28-Mar-2013, 11:30 PM   #3
oakleyhoma
Thank you. I've never done a ground block but will examine the diagrams I have some more. And I will certainly have a good drip loop and seal the hole well before I'm done with it. Now, an additional question: Both the ground wire and coax will have to run from the antenna, down the roof, and over the face of the gutter. Is that an issue? Will the gutter rub/cut at the wires if it moves around? How do I keep it from moving and blowing around? I know I don't want to staple them into the roof. Also, after clearing the gutter in a gentle arc, I'd like to pull both coax and ground in to the siding to staple them into the corner as I head down. What kind of staple is appropriate?
oakleyhoma is offline   Reply With Quote
