Old 28-Mar-2013, 9:49 PM   #9
Install a DB4e aimed at about 365 degree magnetic compass direction.
For reception of the UHF channel Digital Tv stations/channels.
____
Install a Winegard YA1713 aimed at about 197 degree magnetic compass direction.
For reception of.
WBPH-TV REAL VHF Digital channel 9 , virtual number (60.1) , Religion.
______________________________
Connect the DB4e Uhf antenna and the YA1713 Vhf antenna together with a , Antennas Direct , EU385CF-1s. UHF antenna / VHF Antenna , Combiner.
Connect the DB4e antenna to the UHF connection of the combiner.
Connect the YA1713 antenna to the VHF connection of the combiner.
The remaining connection of the combiner connects to a , Antennas Direct CPA-19 preamp.
____________
For 1 Tv connected use No amplifier.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
Buy HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com
_______________________________
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path reflecting , blocking , OTA=Over The Air , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
___________________________________________
Here are some Strong and Sturdy antenna mounts.
http://www.ronard.com/Tripods%200703/4712.html.
http://www.ronard.com/909911.html , install the 5 or 7 foot tripod antenna mount.
http://www.ronard.com/34424560.html , install the #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
http://www.solidsignal.com.
http://www.amazon.com.
