Old 28-Mar-2013, 5:47 PM   #4
What you are , aiming for (kind of a pun) , is the Large Group of Digital Tv stations/channels to the , east south east.
Looking at the tvfool Pending Applications Included Digital channel list.
Looking down the channel list from the top to the bottom.
If weak signal strength , Canada Digital Tv station , CICO-DT Digital UHF channel 32 , TVO.
http://en.wikipedia.org/wiki/TVOntario , is received then that is very good.
___________
WHTV Digital UHF channel 34 , virtual number (x) , MyNetwork.
WLNS-TV Digital UHF channel 36 , virtual number , (6.1) CBS.
Are very strong signal strength at your location and will be received through the back and back angle of the HD7698P antenna.
_______________
The Best Practice is.
Each time a splitter split takes place the signal is reduced.
Use the splitter that has the number of output ports that is the number of Tv's that are connected.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
_______________
Try reception without the Electroline distribution amplifier.
CICO is the , target , Weak Signal Strength Digital Tv station to receive.
If CICO is not received , then install the distribution amplifier.
(((( Please note , If the distribution amplifier is not being used , then the distribution amplifier -->Must Be Completely Disconnected<--.
Unplug it and remove/disconnect All coax cables. ))))
