Old 28-Mar-2013, 6:39 AM   #5
The following is a - Clear - Clean - Simple - recommendation.
Here is a 1 antenna shot at reception of.
WPTX-DT Real Digital UHF channel 43 , virtual number (51.1-2) , CW and Me-Tv.
WPME-DT Real UHF Digital channel 35 , virtual number (35.1) MyTv and Maine Visitors Channel.
WCBB-DT Real VHF Digital channel 10 , virtual number (10.1) PBS and PBS World and Main Capitol Connection.
WGME-DT Real UHF Digital channel 38 , virtual number (13.1) CBS.
WFPO-DT Real UHF Digital channel 23 , virtual number (23.1) FOX.
WMNE-LP Real UHF Digital channel 32 , virtual number (32.1) TBN.
WMTW-DT Real VHF Digital channel 08 , virtual number (8.1) ABC and Accu Weather.
WCSH-DT Real UHF Digital channel 44 , virtual number (6.1) NBC and Weather.
_____________________
Antenna rotator Not Required. Antenna rotators Are Not channel surfing friendly , must wait for the antenna to rotate and There Will Be Domestic Issues about the direction the antenna is aimed when using a antenna rotator.
Above the roof in such a manner that the roof and house are not blocking reception to the , east , south , south west.
Install a Antennas Direct , Clear Stream 2 Complete UHF/VHF antenna aimed at about 215 degree magnetic compass direction.
http://www.antennasdirect.com/store/...VHF-Combo.html.
Remove the Reflector Screen of the CS2 Complete antenna and the CS2 Complete antenna will receive at the front and back of the antenna for reception of.
PBS and FOX to the east.
And
CW , MeTv , MyNetwork , CBS , NBC , ABC , TBN , and Etc. , to the south and south west.
_______________
Install a Antennas Direct , CPA-19 preamp.
_______________
For 2 Tv's connected use a HFS-2D , 2 way splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
____________
Here are some roof top antenna mounts.
http://www.ronard.com/909911.html , install the 5 foot or 7 foot tripod antenna mount.
http://www.ronard.com/34424560.html , install the #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the soildsignal search box or buy from ronard.
___________
http://www.solidsignal.com.
http://www.amazon.com.
_______________________
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path reflecting , blocking , Digital broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the CS2Complete antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channels Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable channels.
Go into the Tv Setup Menu and select , "Air Channels' / 'Antenna Channels'.
Last edited by teleview; 29-Mar-2013 at 6:04 AM. Reason: Correcting typos , clarifying , providing more information
