Old 28-Mar-2013, 12:10 AM   #1
jzinckgra
Struggling with reception
Here is my analysis:
http://www.tvfool.com/?option=com_wr...1dda08d91b12a0
I have tried a couple different directional antennas before realizing I probably needed an omnidirectional. I can easily get ABC, NBC, CBS, but Fox (23.1) is the tough one since it's in a different direction then the others. The most recent directional I have used is a Terk HDTVO. This is mounted outside ~15' above the ground, attached to 50' of RG6 then into the amplifier. I gave up on this antenna and just tonite tried a brand new Winegard MS-2000 omnidirectional. I had high hopes, but the results are the same.
Any thoughts? All I care about are the major networks, but I can only get 3/4 of them. I may be able to put the antenna up another 5-8' high, but not sure that will do much. I'm kinda surprised since we're on a hill at 720'. Thanks.
jzinckgra is offline   Reply With Quote
