Old 27-Mar-2013, 10:15 PM   #4
A simple reception situation that will receive , many , many , many , many , Digital Broadcast Tv stations/channels.
Above the Peak Of the Roof in such a manner that reception is not blocked by the roof and house in the directions of , east south east , south , south west , north west , install a Antennas Direct , Clear Stream 2 Complete Uhf/Vhf antenna aimed at about 155 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.cm/antenna/pointing/pointing.html.
http://www.antennasdirect.com/store/...VHF-Combo.html.
The CS2 Complete comes with a , J type antenna mount.
Remove the reflector screen from the CS2 Complete antenna and the CS2 Complete antenna will receive at the front and back of the antenna , for even more Digital Tv stations/channels to receive.
The reflector screen is not the UHF reception loops.
The reflector screen is not the VHF reception rods.
The reflector screen is the screen , remove the reflector screen.
_________________
Also install a Antennas Direct CPA-19 preamp.
____
For 4 Tv's connected use a HFS-4D , 4 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
_____
Here are places to buy antennas and etc..
http://www.solidsignal.com , http://www.amazon.com.
__________
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path reflecting , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the CS2 Complete antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select, 'Air Channels' / 'Antenna Channels'.
