I see 2 splitters. Remove them.
The input of one of the splitters has what looks like some type of double coupler. Remove it.
Remove ->ALL<-of the cable Tv hardware that is connected with the antenna system.
Remove ->All<- of the preamp , remove the preamp , remove the power injector , remove the power supply.
For 3 Tv's connected use a simple common 3 way splitter.
For 4 Tv's connected use a simple common 4 way splitter.
For 5 Tv's connected use a simple common 6 way splitter.
Leviton 47690-6 , 6 way splitter.
__________
Know this--> each time a splitter split takes place the signal strength Is Reduced.
Terminate unused splitter output ports with 75 ohm terminators. The 75 ohm terminators keep the system balanced and prevent ingrees and egress.
___________________________________________________
If you have cable internet service or any other type or kind of cable tv delivered service , the cable delivered service ->Must Not<- be connected to the antenna system in any shape way or form.
Zip , Zero , Zilch.
_____________________________________________________________
Antenna system amplifiers , preamplifiers / distribution amplifiers Are Not the Cure All for antenna system problems.
Amplifiers Are Not the alpha/omega.
Amplifiers Will Not fix bad coax.
Amplifiers Will Not fix bad connections.
Amplifiers Will Not fix multipath/reflections.
Amplifiers Will Not fix all reception issues.
Know this --> Automatic reaching for and installing a amplifier is automatic reaching for trouble.
