Old 25-Mar-2013, 4:32 PM   #19
geobrick
Thanks. I plan to move it back to where the signals were stronger and then play with it to see if I get KNBC. I know the stucco has that mesh imbedded in it and that could be acting like a shield. If that doesn't work, I'll look into the 91XG.
The signal strength I was getting for all the other stations wasn't marginal. According to the signal strength meter on the Tivox converter I was using in the attic, the unamplified signal on most channels was well into normal area and KCBS was in the green area (upper third of the scale). I think things are fairly good in the attic considering how much signal can be lost or scattered in there.
geobrick is offline   Reply With Quote
