I have it aimed at 274 degrees.
Do you think if I removed the preamp and just ran the line I have fed into the basement directly into a tv in the basement that would work?
I don't have enough cable to run a new drop line to test. I could buy some if i had to.
If that works then I would assume there may be a problem with the preamp correct?
I will run the tests you suggested tomorrow afternoon and let you know what I come up with.
Thank You!
