Old 25-Mar-2013, 12:09 AM   #2
elmo
What direction are you aiming? 270ish? Not that it much matters for those that are so close to you.
First thing I'd do is try the most simple install, removing all other factors. If you can, run a single drop from the antenna to a single TV and scan for channels. Make sure you have the TV set to OTA & not cable. From there tweak until you get the best reception, then change out to the permanent cable run. See how that works for the same TV, then connect the splitter, and if the split is too much loss for reliable reception for all TV's, then connect the preamp.
