Old 22-Jan-2010, 5:46 AM   #6
mtownsend
Originally Posted by FolFool View Post
I don't have a clue how I'll mount this yet. First I need to make sure it will even fit up there (I believe it will, but it's pretty tight between vertical beams -- about 2 feet).
There are some simple mounting brackets that can be used to hold a short mast (either hanging from above, or coming up from the bottom).
The antenna itself is designed to clamp onto a vertical mast (just about any pipe up to 1.5 inches in diameter will do). This will hold the antenna in mid-air so that it doesn't come into direct contact with anything else.
