Old 22-Mar-2013, 3:08 AM   #8
BobHaskett
Generally you'll find the most effective location for an amp is at the antenna. That's because an amplifier can only overcome the losses and noise issues of components on the output side of the amp. Amplifiers do not / can not 'pull' signal from the antenna, cable or air. If you don't have a good signal from the antenna, you'll only amplify the noise and low quality signal. Making it a noisy low quality signal more powerful is not an improvement, amplified noise is not going to help the tuner recover error free data. Then to make matters worse, even the best amplifiers add a bit more noise of their own.
Most digital TV signal meters offer some indication of signal quality... usually based on digital error rate rather than signal power level. So once you have added enough amplification to overcome the losses and tuner noise figure in your system, you'll see little if any additional improvement in meter readings. So there's little to be gained from amplifier gain in excess of the sum of cable losses, splitter losses and tuner noise figure. In fact excess gain invites distortion that interferes with reliable reception.
Bottom line, reliable reception is primarily a function of the antenna choice and it's location. Antenna gain is better than amplifier gain.
Great info. Thanks.
Last question...When using, say, a 6-Way splitter. Is there any difference in terminating the unused ports on the actual splitter connection vs. connecting a coax with no TV attached?
I have a 6-Way passive splitter at the moment. Each split goes to a different room in the house. We do not yet have TVs (but will eventually so I went ahead and ran the coax) in 3 of the rooms. Would it be fine to leave the coax connected to the splitter? Or should I go under the house and terminate the unused ports until we get a TV for those rooms?
BobHaskett is offline   Reply With Quote
