Old 20-Mar-2013, 6:47 PM   #10
Try aim the ANT751 at 83 degree magnetic compass direction , at K23HT-D REAL UHF Digital Channel 23 , virtual number (x) PBS.
K23HT-D is a repeater Tv station for KUID-DT REAL VHF channel number 12 , virtual number (35.1) Idaho , PBS.
KUID is further away and has 2 edge path obstructions = hills/mountains.
More on KUID later.
________________________
Looking at Pending Applications Included tvfool radar report and channel list , and , doing research using the google search box I found that ,
(( in the google search box , type in variations of the Tv station call sign , example , k23ht , k23ht tv , k23ht-d , k23ht-d 23 , and so forth.
The web sites that google will find that have the most Practical and Useful information that is Easy To Use , are , wikipedia and rabbitears.info.))
KXLY-DT channel 13 ABC and Me-TV.
KXLY channel 22 ABC and Me-TV.
KXMN-LD channel 17 Me-Tv.
So no requirement to receive , KXLY-DT channel 13.
_______________
KDYS-LP channel 32 , Daystar religion. Weak signal strength.
KQUP channel 24 , Daystar religion. Strong signal strength.
So no requirement to receive KDYS channel 32.
_______________
KWSU-TV channel 10 PBS.
KWSU-TV channel 17 , same PBS.
So no requirement to receive KWSU channel 10.
_______________
KLEW-TV channel 22 , is Very Weak Signal Strength.
And will require a Large UHF antenna to receive.
More on that later.
_______________
At this point , this eliminates the 2 extremes of directions of the , North East Digital Tv stations channels and South East Digital TV stations channels.
And the VHF Digital Tv stations channels with exception of , KSPS-TV channel 7 , Spokane PBS. KSPS is strong signal strength at your location.
__
This all being the situation , aim the ANT751 at about 83 degree magnetic compass direction , K23HT-D channel 23 PBS.
_______________
And now alternatives.
A better antenna for reception of the UHF Digital TV stations/channels and the 1 VHF Digital Tv station/channel KSPS-TV 7 PBS.
Is a Channel Master CM4228HD antenna , the CM4228HD is a High Gain UHF antenna and does a fair to good job of receiving the VHF high band channels of 7 thru 13.
Aim the CM4228HD at about 83 degree magnetic compass direction.
___
You can use the CM4228HD to Test reception of KLEW-TV channel 22 CBS , by aiming the CM4228HD at about 131 degree magnetic compass direction and at the same time will be Testing the reception of KUID-DT channel 12 PBS 138 degree magnetic compass direction.
__________________________________________________________
The ANT751 antenna can Test reception of KUID-DT channel 12 , PBS. 138 degree magnetic compass direction.
The ANT751 antenna can Test reception of KLEW-TV channel 22 , CBS. 131 degree magnetic compass direction.
____
As always , the starting antenna aim direction is the --> starting antenna aim direction.
The antenna aim direction can be adjusted for best reception.
Most Digital Tv's have a signal strength meter and some Digital Tv's also have a signal quality meter.
What is the make and model number of the 10 dB amplifier??
Also , Weather->Water , can get into the matching transformer that connects the ANT751 antenna to the coax.
Replace the matching transformer (balun) with a Channel Master CM-94444 matching transformer.
Also Water can get into the connections and coax that are outside , recommend replace outside coax with the coax that has the Compression type connectors on the ends of the coax , not the Old crimp type connectors on the ends of the coax.
And replace other connectors that are exposed to Weather->Water.
To make double sure that water does not get into the matching transformer and coax connection's , outside connectors , outside coax.
Wrap the ->Complete<- matching transformer the wires end , the body of the matching transformer the coax connector end and the coax , with , Coax Seal , http://www.coaxseal.com.
Wrap other outside connections etc. with coax seal.
___________________________________________________________
As always , trees and tree leaves , plants and plant leaves , do a good job of , multipath/reflecting , absorbing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and building.
It is best to install or test antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
_____________
Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do a Double Rescan.
http://www.dtv.gov/rescan.html.
