Old 19-Mar-2013, 7:53 PM   #5
The pre-amp goes on the mast at the antenna. The power supply is typically located just "upstream" of the splitter distribution box.
However, you should not need a pre-amp. A four port distribution amp should work well if any amplification is needed.
