Thanks for your input Teleview...Got me sold on the Kitztech PreAmps, definately going to order one, looks like worth every nickel...
I am assuming you meant the CM4228 and not the CM4428???...If so, why do you recommend the CM4228 over the DB8e as the DB8e has plenty more gain??? and it's not much larger in dimensions???...and do you think the CM4228 will bring in channel 22(66) Fox that reads -16NM(db) on my tvfr???
"Maybe I was doing my math wrong but was assuming to pick up a station -16NM(db) I needed at least a 16 dbi antenna..."
I have one direct line to one TV with no splitters and 25ft run
P.S. according to my tvfr, my NM(db) does not change much 60 ft and under, 1/2 to 1 NM(db) if lucky as I have considerd a tree or small tower...
