Thanks for the info, great feature...No, that did not work out very well either as the 5 acres here is flat land and tried almost every location...From the look of things and my limited options, I should concentrate on getting channel 22(66) Fox that has about a -16.4 NM(db) as I do get channel 50, -10.3 NM(db) at %40(4 bars) steady signal with my currant set-up of antennas...I think the gain with both my antennas is about 13 to 14...
Think it's time to do some math to see what db gain I have now and what I will need to overcome the -16.4 NM(db) to receive at least %40 signal...From the look of things, does not look like the DB8e will work alone for Fox Channel...looks like 2 or more antennas is the only option???
