Success! Got Channel 5 and much, much more!
Was pilot error: ! wasn't using the channel selector on the HDTV's remote properly. When I finally checked signal strength coming in...there was Channel 5...strong as can be. Caramba!!!
I did get an RCA PreAmp to match the ANT 751. But per your advice...I will hold off until I can see what kind of signal I'm getting all the way around to TV#2. It's 80+ feet from the antenna to the splitter(above the DISH dist.). Then another 92 feet from there into the back bedroom (TV#2). Could I split right at the antenna...and run an exposed coax across the roof to TV#2???
Anyway... I still haven't "cut the cord", but getting there. Thanks to all. Any further advice appreciated. Dan
