Old 15-Mar-2013, 11:33 PM   #19
Here are antenna mounts.
http://www.ronard.com/909911.html. If you choose tripod antenna mount use the 5 foot antenna mount.
http://www.ronard.com/Tripods%200703/4712.html. 10 foot tripod antenna mount.
http://www.ronard.com/34424560.html. If you choose the eave antenna mount , use the #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at , http://www.solidsignal.com , by typing the word ronard in the solidsignal search box or buy from ronard.
Here are , Aluminum , Light Weight , Free Standing , No Guy Wires , Lay Over Towers , Do All antenna mounting and adjustments , Standing on the Ground.
http://WWW.palcoelectronics.com/pe300.aspx.
You can also type the words , tv antenna mounts , in the google search box.
Do not install the HD7696P antenna any lower then 28 feet above ground.
