Old 21-Oct-2010, 11:48 PM   #2
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
First of all, any antenna that quites 100-150 miles of range is just plain LYING! Now, in the days of digital TV, most TV stations are actually spaced closer to one another than that, and digital reception falls off a cliff, literally, at about 65 to 70 miles from the transmitters, except in very rare conditions, such as where the transmitters are located on top of very tall mountains, such as in Burlington, VT and Boise, Idaho. Unfortunately, NYC does not fall into that category.
Mt. Kisco is only about 35 miles from the ESB, but you are blocked by hills from a direct line of sight to the transmitters, hence, while TV reception is available at your location, you will need a large antenna to insure good TV receptio
Based on your TVFool.com report, I would suggest a deep-fringe VHF-high-band plus UHF antenna like a Winegard HD-7698P or an AntennaCraft HBU-55. Both antennas are very large and powerful, but some may object to their size. The ideal situation would be to install such an antenna on the roof, as high as is practical, and add an antenna rotator like a Channel Master 9521a and a preamplifier like a Winegard Ap-8275 or a Channel Master Titan 7777. The rotator will allow oyu to turn the antenna from NYC towards CT so that you have the alternative of watching other network channels . If only NYC is of interest to you, then you can forgo the rotator, but I would recommend using the preamplifier, especially if you plan to run multiple TV sets from the one antenna. Such an antenna system will provide reliable reception of the major NYC stations.
