The information does not solve the problem of multipath (out of phase signals) when the antenna panels are aimed in different directions. And does not minimize the problem to the point it is not a problem.
The information does not solve the problem of signal strength bleed off of signal from one antenna panel to the other antenna panel when the antenna panels are aimed in different directions. And does not in any way minimize the problem of signal strength bleed off to the point that it is not a problem.
A modified directional coupler is one way to somewhat solve the problems , however there is a big signal strength loss (dB) when using directional couplers.
