Old 14-Mar-2013, 5:50 PM   #11
BTW, here's what's in the Mohu...
The 7698 might not be the most appropriate antenna for this situation unless you're also using a rotor. All of the stations to the south east are UHF and the only two VHF stations in the area are from New Haven and Springfield. You'd likely have to re-aim that antenna to pick up either of those stations.
You can greatly improve the accuracy of your TV Fool report by performing the following, a message I often send to e-mailers who contact us for assistance:
In order to perform a more accurate assessment of your possibilities, we will need your GPS coordinates (latitude/longitude).
If you don't have them handy, proceed as follows:
Go to http://www.tvfool.com/?option=com_wrapper&Itemid=90
Enter your full address and hit "Map This". You will get a Google map with its guess as to your location. Drag and drop the red balloon to your approximate location, click on "Hybrid" to switch to a combined map/satellite view, then fine tune the location by adjusting the balloon's location on the map onto your rooftop.
Under the lower left of the map will be a set of numbers similar to 36.410621,-92.239341
Those are your GPS coordinates and are what I'll need to do an accurate assessment. Copy and paste them into your reply.
You can use those coordinates to come up with an exact location report.
The orientation of your home relative to hillsides and the surround trees also makes your situation somewhat iffy. I'd actually have to look at the terrain and satellite views of your location to better analyze your possibilities.
