[/QUOTE]You said, "I only care about digital channels 19, 20, 27 and 42." Per the radar plot, those stations are close together so if you choose to try a more directional antenna, you should not have a problem aiming at the group.[/QUOTE]
And, if you add a VHF-high-band plus UHF antenna and a rotator on the roof, you'll not only see the the Mt. Royal stations, but also the Mt. Mansfield, VT stations, as well. I recommend a Winegard HD-7696P mounted on top of a good rotator like a Channel Master 9521a or an AntennaCraft TDP-2. Rooftop mounting will help you with ALL of your stations, as roofing material, insulation, and such severely cuts down on the signal available to your antenna, and will can cause the multipath distortion that you are currently see as pixellization and picture dropouts.
