Old 14-Mar-2013, 3:11 AM   #10
Install the antenna , Up High.
Install the antenna Above The Peak Of The Roof in such a manner that the roof and house are not blocking reception.
As always , trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind including your own roof and house.
Moving trees in the wind causes , Moving , multipath/reflections.
The computer of the Digital Broadcast Tv Tuner can correct a certain amount of moving and stationary multipath and then at some point , ( to much) , the computer can not correct the moving and stationary multipath the picture will break up into blocks and/or the screen goes blank.
Also traffic and airoplanes cause moving multipath/reflection reception.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
