Old 13-Mar-2013, 10:57 PM   #5
The provided tvfool radar report plot and channel list says.
Address was only resolved to the block level and might not be that close to your actual location. For more accurate results , try entering a specific address and coordinates.
________________________
By pass a smaller 'Testing' antenna and go straight to the reception.
Based on the provided tvfool report.
Install a Winegard HD7698P antenna with a Winegard HDP-269 preamp , aimed at about 160 degree magnetic compass direction.
Install the HD7698P antenna Above The Peak Of The Roof in such a manner that the reception is not blocked buy the roof and house in the directions of , south east / east / north east.
______________________________
As always , the starting antenna aim direction is the -->starting antenna aim direction.
The antenna aim can be adjusted for the best reception.
Most digital Tv's have a signal strength meter and some digital tv's also have a signal quality meter.
Here are some Strong and Sturdy antenna mounts.
http://www.ronard.com/909911.html. use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. use the #4560 eave antenna mount.
http://www.ronard.com.
Here are some places to buy antennas and etc..
http://www.solidsignal.com.
http://www.amazon.com.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
_________________________________
For coax that is outside exposed to , weather/water , use coax that has the Compression type connectors on the ends of the coax , not the Old crimp type connectors on the ends of the coax.
To add more protection from weather/water getting into the outside connections and coax , wrap the connections and coax with , http://www.coaxseal.com
As always , trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , OTA=Over The Air , Digital Broadcast Tv Reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7698P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
DO NOT channels scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
