Old 13-Mar-2013, 6:03 AM   #2
So my question is what antenna should I use and how high does it need to be to get WDCW, WPXW, WETA and WDCA.
'Go big or go home', mount an Antennas Direct 91XG or DB8E at 29'. Equip it with an Antennas Direct CPA-19. Cable it separately from your existing system, run to a dedicated tuner such as a SiliconDust HDHR3-US. If you want to access the 'DC' antenna from a conventional TV, run a second drop to the TV and use an A/B switch or HD capable set-top-tuner to terminate the 'DC' signal. http://forum.tvfool.com/showthread.php?t=2882
