If I was in the same situation, I would opt for a large high gain antenna such as the Winegard HD7698P. I would mount as high as practicality and safety allow.
An Antennas Direct PA-18 or CPA-19 preamp would be my choice for amplification. This would overcome the losses in cable and splitters, but as you may already know, an amplifier does not / can not 'pull' signal from the antenna or air.
Reliable reception starts with the antenna and it's location. As you have already acknowledged, the ANT-751 is too small in this case.
