Old 13-Mar-2013, 2:39 AM   #10
KYTX-DT REAL UHF Digital channel 18 , virtual number (19.1) CBS is your Weakest receivable Tv station of the group of Tv stations to the south / south east.
Aim the CS4 antenna at about 167 degree magnetic compass direction.
Install the CS4 antenna above the Peak Of The Roof in such a manner that the roof and house are not blocking reception to the , south / south east.
http://www,ronard.com/909911.html. use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. use the #4560 eave antenna mount.
http://www.ronard.com.
________________________________________________
The device that you think is a splitter is most likely the Power Injector that connects the power supply to the coax so the power can travel through the coax to the actual preamp out by the antenna.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
As always trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , Digital Broadcast Tv Reception and so do buildings and other obstructions including your own roof and house.
It is best to install the antenna at a location that has the least amount to No amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , often namrd the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels / 'Antenna Channels'.
If the CS4 antenna does not quite provide reliable reception.
Then install a Winegard HD7698P antenna in places of the CS4. Remove the CS4 completely and install the HD7698P antenna.
To help keep water out of outside connections and coax.
For outside coax , use the coax that has the Compression type connectors on the ends of the coax , not the Old type crimp on connectors.
Water that gets into the outside connections and inside the outside coax will make for Bad reception.
To make double sure that water does not get in the connections and coax , wrap the connections and coax with http://www.coaxseal.com.
